Turn signal glitch
Old Jul 16, 2014 | 10:43 PM
Blue SOG's Avatar
Blue SOG
Until I added the Badlands, I just held it down best I could. But, I've since then stripped off the turn signals altogether. Point and hope for the best! (use hand signals)
Old Jul 17, 2014 | 05:45 AM
Kabear's Avatar
Kabear
Blue SOG: Without a doubt this is the ideal method, I use it often.
Omaha: Actually the switch for the manual turn signals is different than the switch for the self cancelling, therefore they are a little easier to hold on whilst using the clutch/throttle.
They have a little nib on them where as the newer type is just flat, this is one way you can tell if you had the original manual type or the new self cancelling type.
Old Jul 17, 2014 | 06:00 AM
das56170's Avatar
das56170
I have a 94 FXSTC which originally had the self-cancelling turn signals. However, the module under the tank that controls this just died, so I ordered the Badlands module. I'll be installing this weekend. I'll let you know how it goes.
Old Jul 17, 2014 | 06:39 AM
Tom84FXST's Avatar
Tom84FXST
Harley toyed with self canceling on some models in the early 90's, which were problematic...they did not get it right until they changed to the electronic speedo...96 on softails...some models lagged a year or two behind.
Old Jul 17, 2014 | 09:39 AM
Uncle G.'s Avatar
Uncle G.
Just FYI, the self canceling turn signals arrived in '91, so your '90 wouldn't have them, Neither did my '89 Sporty. You had to hold the button down to keep them on.
One year (it may have been '86, not sure), the signals were push on/push off. Problem with that is, of course, remembering to turn them off. I know this issue well, since I lost my self-canceling feature when I changed my speedo to the '62 style (no reed switch in the speedo).
Old Jul 20, 2014 | 09:15 PM
das56170's Avatar
das56170
Just installed the Badlands turn signal module.
When my turn signals were working, I would push the button once to turn on, and once to turn off. If I didn't turn them off manually, they would turn off automatically after a certain distance depending on my speed (reed switch from speedo)
Once the OEM module crapped out, I would push the turn signal button and the the signal would come on, but not flash (this would happen for either signal) The only time they would flash is when I hit them simultaneously and then my hazards would work the way they were supposed to.
wiring up the badlands module was pretty simple. All original wires from the bike are used, except the one from the speedo reed switch. Now the signals work just like before (turn on/off manually). They will also cancel automatically after 11 seconds, regardless of speed (since not connected to speedo)
Overall - great product for replacing broken OEM module, or for older Harleys that didn't originally have self-cancelling signals
Old Jul 21, 2014 | 05:22 PM
machinehed's Avatar
machinehed
Default no turn signal cut out.
Originally Posted by machinehed
Find your manual ! Suck it up or have a dealer rape you for all your worth ! Then clean every wiring connector you can find as per. this thread page .
Then look for the ground block at the left fork tube area . Clean it too.
She is 24 years old and the wiring is same ?
See page 8-32 on Harley manual 1984-1990 for check out procedures for the turn signal self cancelling system .
Old Jul 22, 2014 | 06:50 AM
Granpita's Avatar
Granpita
This was the first thing I noticed when I got my '84 FXRT. When I asked about it, I was told it was "the ultimate in self-cancelling signals". So far, I've never felt the need to change it.
Rick5150
EVO
Aug 14, 2016 08:44 AM
BMCsteve
Oct 24, 2013 10:28 PM
Solly
Jan 27, 2013 01:50 PM
Shane70987
Mar 14, 2009 09:08 PM
hddawg
Apr 6, 2006 01:00 AM
