Front Brake Nightmare
Old Jul 29, 2014 | 08:00 PM
machinehed's Avatar
machinehed
Default bleeding harley brakes tip.
I have found that the bleeding process itself can introduce residual crap into a very small return hole in the bottom of the brake fluid master cylinder.
Try using a wet/dry vacume with a home made attachment to suck out the entire master cylinder and the offending small return hole .
Rebleed the system and hopefully this will be the fix.?
Old Jul 29, 2014 | 09:09 PM
Throttle_Jockey's Avatar
Throttle_Jockey
And since your question wasn't clearly answered...... Yes leave the cap off. Lay a rag accross the MC to prevent dust contaminants.
Old Jul 30, 2014 | 03:58 PM
boygenius's Avatar
boygenius
Well in morning lever was still floppy , got desperate and started tapping on all the fittings and stuff then took a syringe and sucked all the the old fluid out of master cylinder , and all the sudden bam , the lever became firm
Old Jul 30, 2014 | 06:01 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
I'm glad you got it fixed.
I wonder did you suck anything out of the return hole at the bottom of the master cylinder?
Old Jul 30, 2014 | 06:52 PM
boygenius's Avatar
boygenius
i looked in the syringe but didnt see anyhthing , i really have no explanation as to what fixed it lol
Old Jul 30, 2014 | 07:09 PM
99Birdman's Avatar
99Birdman
That happens every time I replace pads or remove my front wheel. I usually end up pushing the caliper pistons back into the caliper in the process and they need to be returned to the extended position. No need to bleed the brakes but, rapidly pump the lever until some resistance is felt. This may only be at 1/2 travel but, hold for about 5 seconds then repeat the pump and hold process until the lever gets firm. Works everytime for the last 20 years.
Old Jul 30, 2014 | 07:29 PM
boygenius's Avatar
boygenius
well its fixed lol , now if i can find out why my s&s carb throttle pull is so much stiffer than my dads cv carb........
Vinish
May 4, 2026 05:45 PM
Falcon195
General Topics/Tech Tips
Dec 6, 2015 01:17 PM
Edster 69
EVO
Jul 21, 2011 06:51 AM
AluminumGT40
Wheels/Tires
Sep 16, 2010 03:50 PM
Aussiecraig
Jul 14, 2009 12:40 PM
