I think it is more "amp death" related than anything else other than cheaper materials in some cases. Seems the more output on amperage, the quicker they go.
I run a 38 amp in my 94 carbed dresser and it is over 8 yrs old and going strong.
My 76 shovel had 186k on it when I stroked it in 2005 and was on the same stator since I got it in 1978. Several regulators, but same stator. Still works too, although it is not in there any longer. I still just run the 17.6 amp in the shovel as that's all it needs.
I splice my older stator connections and run leads outside of the cases and silicone them up inside and out. Never a loose connection and they work way better for me like this. Swapping a reg is just cut and add connector to ends and connect it..
Griz
i did the same on my shovel. that plug can be a problem
Ok, now for the smart *** answer, It should last till it quits working. Kinda like how long should a man live? Or how about which oil is the best? Or what size tit's are perfect?
I bought a pristine 1995 Road King last year, with 9,000 miles, that had been sitting up for maybe 15 years. Got cranked I think periodically, but not much.
I bought it, and stator either failed then, or was already kaput. Sold the bike to a good friend for what I had in it, and he replaced the stator last summer with the HD OE part.
Failed again this summer 5,000 miles later.
Did he put a new HD OEM regulator in at the same time? If not, that could have been the problem, otherwise he has an intermittent short in the electrical system somewhere.
I don’t know if he did the first time he replaced the stator last summer, although I included a NIB OE regulator with the bike when he bought it. I’m pretty sure he has it on now with the second stator.
