Bike left me hanging
Old Aug 31, 2014 | 11:52 AM
Hackd's Avatar
Hackd
Originally Posted by Dr.Hess
..And, for the record, a Harley big twin Evo will run 60MPH fully loaded on the front cylinder only with zero compression on the rear.
Well, that's reassuring.
I guess.....
Old Aug 31, 2014 | 02:39 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
This is a fun fact that I hope to never find out for myself!!!
Old Aug 31, 2014 | 06:28 PM
machinehed's Avatar
machinehed
Default no go .
Originally Posted by spanky02
I am sitting waiting for a trailer to come pick me up as I type this... My bike started missing, one cylinder firing one not intermittently. Didn't matter how much load was on it low rpms or high rpms. It got real bad so I pulled into a gas station.. When I went to start it back up it only fired on one cylinder.. Ignition module? The coil has been replaced because it did something similar before and the coil tested bad so it was replaced.. Bike has ran fine until now..
Ok. so ... new coil replaced because it did this before , we can eliminate the ign. modual as it would provide no spark at all unless a bad connector.
Go to spark plugs first , then check for voltage leakage at plug wires in a dark room to check for leaking spark.
Check all signal wire connections to coils for looseness etc.
Use a cheap spark plug testor to check for proper spark at the offending cylinder . Come back with results.
Old Sep 2, 2014 | 08:12 PM
spanky02's Avatar
spanky02
I couldn't find anything so i took it to my independent.. We shall see what he finds.. Thanks for all the replies
Old Sep 2, 2014 | 09:19 PM
Tee&Vee's Avatar
Tee&Vee
For a teachable moment please report back.
Thanks,
Tom
Old Sep 3, 2014 | 06:34 AM
carlgrover's Avatar
carlgrover
I can't speak for an EVO but everytime my ironhead would run on one cylinder it was always that durn rear exhaust pushrod adjustment.
carl
Old Sep 4, 2014 | 02:55 PM
spanky02's Avatar
spanky02
is it possible a bad speedometer could cause these symptoms? my speedo went bad around the same time. my year bike sucks to try and find a speedo...lol. we are gonna give it a shot because everything else is testing out ok
Old Sep 4, 2014 | 03:13 PM
Dr.Hess's Avatar
Dr.Hess
No, not the speedo. And, ahhh... if your indy is suggesting the speedo is causing the rear cylinder to miss, ah... it's time to find a new indy.
When the bike is missing, that's when you need to diagnose it. Did you ever check the compression? Did you ever check for spark? Did you ever replace the rear spark plug? Did you swap the plug wires at the coil?
Old Sep 5, 2014 | 07:15 AM
junglejoe's Avatar
junglejoe
And the mis was because of??..... NOT from the speedometer, that's a fact!
Old Sep 26, 2014 | 05:21 AM
spanky02's Avatar
spanky02
it ended up being the coil all along. runs like a raped ape! thnaks for all the help.
