SUSPECT CARB PROBLEM
Old May 1, 2007 | 11:14 AM
05HARLEYMAN's Avatar
05HARLEYMAN
6th Gear
Default SUSPECT CARB PROBLEM
Has anyone ever experienced the following:
05 heritage, 88b, carburated, 29,000 miles with no problems other than those caused by "trained" mechanics and fixed by me.
I was approx. 120 miles into my weekly commute along I-5, cruising along at roughly 70 with my little trailer behind which had really no load in it.I was about half way up a gentle grade when the engine started to loose power; i nursed it to the top and pulled over.It would idle reasonablynormal so i sat there for about 5 minutes idling then took off. A couple miles down the flat and level road it kind of acted like it was flooding out or starving. Pulled over, let cool a little, pulled the plugs and found okay, pulled the air cleaner and started it up so i could watch the air slide and accelerator and all looked normal.Buttoned back up and started; finished trip for last 30 mileswhich was just like nothing had ever happened. The last two mornings it's made it to work asusual and i even got on it fairly hard with no problems. I always run the HD fuel additive in every other tank fillup.The day before the trip i change engine oil filter and oil from HD to mobil 1 v-twin 20/50and the only thing different i did during the change was cycle out the HD oil before installing new filter.
Anyone got any ideas? this weekend i will pull fuel **** out and check filter and basic other checks.
If you prefer to talk like in the old days call me on my cell, 425-232-5063
Old May 1, 2007 | 06:35 PM
ohiomotoxer's Avatar
ohiomotoxer
Default RE: SUSPECT CARB PROBLEM
Check the fuel cap breather.
Old May 1, 2007 | 06:47 PM
05HARLEYMAN
6th Gear
Good plan, thanks
Old May 1, 2007 | 11:19 PM
One_Screamin_Eagle's Avatar
One_Screamin_Eagle
Check vacuum petcock
EasternSP
Apr 18, 2019 05:57 PM
Matt990724
Carburetor Related
Jun 25, 2018 09:00 PM
GCSuper
2014-2024 Touring Models
Mar 24, 2014 09:13 AM
TheSeeker
May 18, 2010 05:13 PM
Lurch42
General Topics/Tech Tips
Jun 15, 2005 07:25 PM
