Rough running Dynawideglide '06
Old May 11, 2007 | 05:42 PM
marcss's Avatar
marcss
Default Rough running Dynawideglide '06
Was running really rough when cold and had the fuel injectors switched out (8 degree to 25 degree) and re-flashed per Service Bulletin. Ran great after that for maybe 3 weeks. After running great to and from Laughlin, it's now running rough; coughing, sputtering after every startup for 7 to 15 minutes. Finally runs just o.k. after 20 minutes or so. Still missing a little at lower RPMs. They did the fix at HD at the 5,000 mi service and that was about 2,000 miles ago. WEIRD, Huh? It's not missing and coughing as bad as it was. I could barely even drive it before, but it didn't always do it.
Any one have a similar experience? Got any ideas of what's wrong?
Thanks!
Old May 11, 2007 | 06:47 PM
Doc 1's Avatar
Doc 1
Default RE: Rough running Dynawideglide '06
ORIGINAL: marcss
Thanks!
Marcss, sounds as if the Warm-up Enrichment table is too rich but that shouldn't change once its set with the download or reflash. I'd look for a injector dripping,a bad '0' ring on a injector causing an intake leak, faulty Map sensor or Temp sensor. Hooking up to a digital tec will reveal any sensor problems.
Old May 11, 2007 | 07:55 PM
marcss's Avatar
marcss
Thanks! I'll check into that or at least bring it to the tech's attention at the dealer. I bought this used in December and was able to transfer the orginal owners Extended Service Plan so this should be fixed under warranty. It's one of those problems that doesn't occur all the time and at the same level. It's weird that it was fine for so long, unless it's a new problem with very similar symptoms.
steelerdude1
May 30, 2011 04:36 PM
CHEESE
Sep 1, 2007 04:56 AM
marcss
May 11, 2007 08:02 PM
billk
Jun 8, 2006 01:29 PM
Rodman813
Apr 12, 2006 06:27 PM
