If you've put on another set of pipes or are just re-installing the OEM set, don't forget that you'll need to re-torque the exhaust flange nuts after running a few heat cycles on the motor and remember to put a little bit of anti-seize on the studs.
Tighten the bottom nut to 9-18 inch pounds, tighten the top nut to 100-120 inch pounds, tighten the bottom nut to 100-120 inch pounds.
As mentioned, re-check them often after the initial installation.
__________________________________________________ ____ For ROCKOUT information & purchasing please click the links below...
__________________
NO, they DON'T all do that!
ROCKOUT rocker shaft inserts... make the tapping STOP! From the guy that FOUND and CURED the problem NO ONE ELSE COULD, thank you for your support! Ordering & info http://www.rockout.bizOn ebay! ...CLICK HERE Also on amazon.com...
