2016 FXDLS install question
Old Jan 28, 2017 | 09:29 PM
Pulledunder's Avatar
Pulledunder
Default 2016 FXDLS install question
I recently installed the road rage 3 from Bassani on my Dyna. Looks and sounds great. I've noticed that on both exhaust ports one stud had more threads exposed than the other. I followed the torque specs, and sequence in the service manual. Just wondering if this is normal, or if I should loosen the headers and muffler and re-torque. Thanks!
Old Jan 29, 2017 | 12:36 AM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
You're fine. There's nothing to worry about as long as both the stud bolts have a good bite on the studs. Run a few heat cycles through the engine and then re-torque the bolts to spec. You can then do what I do, double nut the studs or use a crown bolt to "cap" them off.
Old Jan 29, 2017 | 12:40 AM
Pulledunder
Phew haha. Yeah it's like almost 3 threads on one and 5 on the other on both ports. I've got a couple hundred miles on them, as retorqued after the first few rides. Just wanted to double check.
Old Jan 29, 2017 | 11:30 AM
OldEnuf2NoBtr
Just go ahead and double nut them and you won't have to worry any more.
Old Feb 7, 2017 | 02:22 PM
abadley's Avatar
abadley
Is the Road Rage 3 new? I only see Road Rage and Road Rage II on Bassani's website.
Philly1200
May 2, 2015 02:59 PM
DinoM
Sep 18, 2013 05:48 PM
Keithhu
Aug 17, 2012 09:09 AM
JockWhisky
Mar 20, 2009 10:00 PM
malcolm06WG
Jul 29, 2006 12:30 PM
