Louvered vs. Perforated
Old Feb 27, 2017 | 09:42 PM
GibsonSG's Avatar
GibsonSG
Default Louvered vs. Perforated
Looking into a baffle setup for a Rinehart 2:1 on a built 107"...
What are the advantages or disadvantages of the current Rinehart High-Flo louvered baffle setup as compared to switching to a D&D style perforated or perforated wrapped config (custom built)?
I had considered switching to the D&D Boarzilla 2:1 prior to the 124" build-up but I think much like the 6.7 injectors...may be jumping the gun.
How do the baffles influence the general performance & dyno output?
Old Feb 28, 2017 | 02:57 PM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
A freer flowing baffle will generally show more hp, and sacrifice low end torque, and vise-versa.
Scott
Old Mar 1, 2017 | 04:55 PM
qtrracer's Avatar
qtrracer
I was like you. 107" motor, but I had a rb lsr 1.75" 2-1. Went D&D Boarzilla with wrapped perf baffle. It is NOT repeat NOT jumping the gun. Saw 10 hp increase and 3tq increase. Sound level went down as to what I hear. A solid 107" can sho nuf see benefits when fitted with a Boarzilla. Now the 6.7's were jumping the gun, LOL!!!
Old Mar 1, 2017 | 05:25 PM
GibsonSG's Avatar
GibsonSG
I decided to 'tweak' things a bit and see how it turns out...
I pulled the spiral louvered (no wrap) baffle from my existing Rinehart 2:1, took a bunch of measurements and ordered a LA Choppers Universal Baffle with Packing 24inL - 2.5in Dia. (LA-1225-24P).
I'm curious to see how a spiral louvered but unwrapped compares to a perforated (wrapped or un-wrapped), while still in the Rinehart 2:1 in both sound and performance. Then from that point I'll decide on whether or not to keep with the $45 upgrade, or jump to the full D&D Boarzilla route.
As for the injectors, well... I thought that a 6.7 would just simply have a shorter duty cycle and could eventually carry over from the 107" to the 124". They (6.7's) have a 4 port spray pattern and are definitely higher quality than the previous injectors but it was probably just wishful thinking.
I'll post pictures and informal review once I get a chance.
Old Mar 7, 2017 | 06:26 PM
GibsonSG's Avatar
GibsonSG
Here's the baffles side by side for comparison:
I fit the perforated baffle and installed:
Louvered, unwrapped baffle (Rinehart 2:1) stock setup:
Perforated, wrapped baffle:
Initial conclusion: I'm happy with the perforated wrapped as it keeps a good low rumble without being quite as 'percussive' as the louvered design and for my build the back-pressure isn't as necessary.
...of course this is completely subjective as I didn't have a performance baseline of a dyno before & after to show the changes in HP & Torque curves, but it was an interesting $45 experiment.
Old Mar 7, 2017 | 08:23 PM
springers4ever's Avatar
springers4ever
Cool Baffles...
We prefer the perforated design also ...much better sound and contrary to popular belief, we see no loss in low end torque ...when the timing is adjusted properly ...as with any engine mod, you must readjust the tune to gain the full benefit of the change ...
we've noticed better throttle response (on higher compression motors) with the perforated over the louvered and the louvered will tenn to run richer...
the perforated has the perfect tone at cruzing speeds(and that is adjustable by length) ...but will let you hear it well when on the gas !!!
just our 2 cents ...
Old Mar 3, 2019 | 11:01 AM
Monsta Burna's Avatar
Monsta Burna
Stage III
Default Looking for a D AND D Baffle
Hello I just got a D and D 2 into 1 Fat Cat Chrome With the Standard Louvered Baffle I’m Really in Search for the Perforated Baffle I’m willing to Trade either the Baffles With a Ghost Pipe or Whole Exhuast Tip not Headers for Loud set up email me @Benjamin.greene287@gmail.com if interested thanks
rauchman
Aug 1, 2018 06:15 PM
MisterSlim110
Aug 17, 2017 08:47 AM
B00001
Jun 15, 2013 02:26 PM
REALBOB
19
Aug 24, 2008 09:14 PM
bigdumbnoitall00
Aug 19, 2008 05:49 PM
