88 to 96 engine mod.
Old Jun 2, 2007 | 06:59 PM
dognut's Avatar
dognut
Default 88 to 96 engine mod.
Hello to all.Can anyone tell me if I can install stock 2007 96 cylinders,pistons,cylinder heads on my 2006 heritage efi 88. Would I gain anything by this? Or do I need an aftermarket big bore kit? Thanks, tom
Old Jun 2, 2007 | 07:12 PM
Kingofcubes's Avatar
Kingofcubes
Default RE: 88 to 96 engine mod.
THE HEADS AND CYLINDERS WILL FIT, THE PISTONS WILL NOT, YOU WILL HAVE TO GET PISTONS FOR THE 4" STROKE.
Old Jun 2, 2007 | 07:20 PM
xxxflhrci's Avatar
xxxflhrci
You will gain nothing. The bore sizes are the same.
Old Jun 2, 2007 | 07:23 PM
Doc 1's Avatar
Doc 1
Randy is correct....you will have to buy 06 and earlier pistons. As far as gaining anything...no...you would still have a 88'. I have to ask, why do you want to install a '07 top end on your '06?
Old Jun 2, 2007 | 07:30 PM
Dirtrace95's Avatar
Dirtrace95
Have your stock cylinders bored to 95in and use some SE flat top pistons.
Old Jun 2, 2007 | 08:11 PM
Dalton's Avatar
Dalton
The 07 - 96" engine is a "stroked" TC 88. The cylinder bore and size is the same on an 88 and 96 but the pistons will not interchange, and the heads are a bit different.
Start with a TC88, bore it out and you get 95"
Start with a TC88, bore and stroke it and you get 103"
Start with a TC96, bore it out and you get 103"
You will gain nothing by trying to put a stock 96" top end on a TC88
Old Jun 3, 2007 | 07:53 AM
dognut's Avatar
dognut
Thanks everybody,I thought the 07s had a bigger bore & would have been a cheep way to make my 88 a bit stronger.
Two Lane Tramp
Oct 16, 2015 03:28 PM
Insulatorman17
Oct 8, 2015 12:31 PM
mountian man
Dec 29, 2010 02:01 PM
droffas
Nov 11, 2007 02:29 PM
R/T
Oct 12, 2007 12:32 PM
