Carb Specs
Old Apr 10, 2017 | 06:16 PM
pro62k's Avatar
pro62k
3rd Gear
Default Carb Specs
2001 FXDWG with a 95 kit, Andrews37 cams and a 44mm CV carb. What are all the jetting specs that I can use for a ref point
Old Nov 22, 2020 | 03:25 PM
Madnss's Avatar
Madnss
The CV carb will work just fine. Many will disagree with me, but I wouldn’t put a cv on a 100” build. But, I also don’t run cv’s on stock engines. The CV is a bottleneck at the 100hp mark give or take for a 74”-77” sportster FYI.
So, if you’re thinking 1hp per cube on a 100” I sure the heck wouldn’t run a cv.
Old Nov 23, 2020 | 05:33 AM
eighteight's Avatar
eighteight
Late to the party since the OP asked in 2017 but
FWIW: I`m running 48 /190 on a mild 98" with 40mm CV
Cams / Heads/ Compression/ the usual yada yada..
Old Nov 23, 2020 | 07:31 PM
60Gunner's Avatar
60Gunner
I don't think Madnss is saying it won't run respectable but there is some gain to be had going with say an HSR42, or in your case a 45. Maybe even a 48. On the other hand tho I also think there's such a thing as too big of carb, just like throttle bodies, where velocity suffers. We both come from the performance sporty world where dynos have consistently shown this to be the case. The 100hp mark was widely viewed as the point where the cv40 was bottlenecking. Maybe not a lot but.
Look at how soon the 50mm throttle body is deemed best replaced with a 58.
The cv does seem to adjust to things like altitude and barometric pressure changes much better tho.
br549A1
Sep 11, 2014 09:33 AM
MxNut
Dec 30, 2010 05:09 AM
rottie
Mar 27, 2010 09:42 PM
fxstcguy98
Aug 8, 2008 10:10 PM
MT
Mar 6, 2007 06:40 PM
