Exhaust help
Old May 3, 2017 | 09:54 PM
e11charlie's Avatar
e11charlie
Default Exhaust help
Need some help with creating a little better baffle or some way of restricting this. I like the pipes and the looks but **** me in the goat *** they are loud as hell. I have a buddy running the rinehart straight pipes that look similar to the short shots. These are quite a bit louder than those. In essence making it just a little quieter. The diameter of the screen is the standard 1 3/4 and surrounded by fiberglass packing. This end is crimped down a bit to slide into the header pipe. On the other end is a collar thats just shy of 2 3/8 inch that holds it into the outer pipe housing with a screw. Been trying to do some profound brain things all day and can't quiet come up with a solution. I had asked in another thread and someone sent me a link to the thunder torque inserts. Does anyone think those would quiet it down a little? I know they will give me back some back pressure and lost torque. Im just looking for a solution because I just paid $500 for the pipes. I like loud but these are just a bit too much. Any help would be greatly appreciated. Keep in mind I have no idea how to weld.
Attached Thumbnails Exhaust help-51555785668__39d0f278-5e10-455a-80bc-c74b81d7a60f.jpg
Old May 4, 2017 | 07:23 AM
Blackp5ca's Avatar
Blackp5ca
I laughed when I read your thread...nothing like a classic Sandler line to start the day.
I ran into the same issue with my exhaust, loved the look...couldn't stand the sound. I've installed the Thunder Torque inserts into my pipes..maybe took a decibel or two off but certainly didn't make them much quieter. They did help with some low end torque though..a little back pressure isn't a bad thing for street riding.
The baffle you're running there looks to be a straight through shot, my suggestion, check some of the dimensions on the Vance and Hines Quiet Baffles..maybe you can find one in the same diameter as your pipe. I've run those in the past and was pretty happy with the results, they sounded better (almost deeper), performed better, and made the pipes a little quieter. Just my 2-cents.
Old May 4, 2017 | 09:18 AM
98hotrodfatboy's Avatar
98hotrodfatboy
I would call the manufacturer and ask if they make a louvered baffle. It will quiet them down a little and also restore lost low end torque.
Old May 6, 2017 | 12:24 PM
Bafflingbs's Avatar
Bafflingbs
DK Customs makes/sells inserts that screw into the end cap of your pipes. I just bought some and decided to buy a 2-1 instead. But they're supposed to do exactly what you are asking. http://www.dkcustomproducts.com/Thun...nserts_c57.htm
Old May 6, 2017 | 12:39 PM
QC's Avatar
QC
The Thunder Torque Inserts will do what you want. For $25, they are a great product and the service can't be beat. They will provide a nice idle, relatively quiet cruise, and really bark when you twist the wrist.
Old May 6, 2017 | 07:35 PM
e11charlie's Avatar
e11charlie
Well just went to a loud pipe contest and didn't win so I guess thats a good thing. Measured at 117db. Though it was an app on someones phone and not a true decibel meter. Loudest was 124. Thanks guys I will try the TTI.
Old May 6, 2017 | 07:37 PM
kel03's Avatar
kel03
All measured by the same device ?
Old May 8, 2017 | 10:06 AM
e11charlie's Avatar
e11charlie
Yeah.
sbfreak103009
Jun 5, 2013 03:07 PM
Crushrus
Aug 22, 2011 11:12 PM
shooker
Dec 31, 2010 04:45 PM
Joboo1966
Sep 10, 2010 04:42 AM
bikerlaw
Jun 8, 2010 06:28 PM
