Need to drain fuel tank--'04FXST
Old Oct 19, 2005 | 01:23 AM
Johneb48's Avatar
Johneb48
Default Need to drain fuel tank--'04FXST
I am installing a mini tack wiring harness--directions say drain and remove fuel tank to rout wiring harness under tank. I disconnected fuel line (carburated bike) from carb and placed hose in jerry can--opened fuel valve expecting fuel to run out of tank (of course, tank is full). Not even a drop of fuel ran out. What am I neglecting to do here? I need to remove crossover fuel lines in front of tank also but can't til tank is empty.
Old Oct 19, 2005 | 01:26 AM
HDF Tech's Avatar
HDF Tech
Default RE: Need to drain fuel tank--'04FXST
I f you have the vacuum operated petcock, you need to pull a vacuum on the line to the petcock to open it up.
Old Oct 19, 2005 | 09:40 AM
Johneb48's Avatar
Johneb48
Thanks Bill--took a while (full tank) but worked .
High Roller
Mar 14, 2015 07:07 PM
mlrailguy
Feb 6, 2015 01:30 PM
SpyderTB
Oct 27, 2009 09:18 AM
BlackHwk27
Aug 2, 2009 10:27 AM
glideridemike
Feb 3, 2007 11:46 AM
