Engine missing
Old Jun 24, 2007 | 11:06 PM
jerryverrill's Avatar
jerryverrill
Stage I
Default Engine missing
Having trouble with 2002 Roadking Classic. Bike is fuel injected and nothing upgraded to the engine. Engine seems to miss or "hiccup" in usually low rpm and started around 13,000 miles and getting worse. Have changed the plugs and air filter (plugs look good). Also put some dry gas in tank and nothing seems to help. Next step will try plug wires. Have seen on forum before that the problem could be internal fuel lines, but does this with almost full tank. Also seen riders changing injectors from 8% to 25%, but can't figure out why this would start at 13,000 miles?
Old Jun 25, 2007 | 11:01 AM
Doc 1's Avatar
Doc 1
Default RE: Engine missing
Its very possible for the fuel line to have a pin hole....have them changed out. As far as a full tank of gas has nothing to do with the pressure in the lines....it's not gravity feed....the line has 62 lbs of pressure so a hole in the line would rob the injector of the pressure it needs to operate correctly.
Gordito
14
Feb 17, 2017 01:05 AM
Tex_1_rider
Engine Mechanical Topics
Feb 13, 2017 12:11 PM
darkcvc
Aug 12, 2014 06:40 AM
micky
Sep 26, 2010 03:27 PM
tmultra
Oct 8, 2009 06:45 PM
