Is anyone running a Power Commander on a stock 07 twin cam? If so what are the benefits you see just by adding the PC? I want to add a piece at a time and keep it as stock as I can for right now on my 07 Ultra.
If programmed properly it will reduce the heat and also probably gas mileage. Performance will probably not improve much because it will still be choked down by the stock mufflers and especially the stock AC. The gas mileage can be helped with some tweaking in the right places, though. If you don't want to change pipes, I would at least change the air-cleaner (K&N or Ness), as it is the best bang-for-the-buck mod you can do and isn't terribly expensive. I'm sure a map exists for stock mufflers, K&N AC, and PCIII--and in the future if you want to upgrade your mufflers you can obtain a map for that combo.
Fuel Moto is a good source for packages, and will provide map upgrades in the future if you are a previous customer.
