2015 fatboy
Old Mar 12, 2019 | 01:10 PM
Popichulo's Avatar
Popichulo
1st Gear
Default 2015 fatboy
Changed from a 2x1 to a 2x2 exhaust all is good until i slow down to stop when i engage clutch rpm’s go down to 650-700 and i stall. Does not stall when i idle in my driveway only when i disengage clutch to slow down. If i tweak the gas a little bit it rpm’s will come back up and will idle.. i was told when you install new pipes the ecm has to learn and reconfigure for the new pipes? Said it takes a little while ?
Old Mar 13, 2019 | 12:10 PM
nevil's Avatar
nevil
First thing I would do is to clean the IAC. I don't think that at idle the ECM has a lot to relearn just from new pipes. I would also check for exhaust leaks.
Popichulo
Mar 12, 2019 11:37 AM
wiktor
Jan 14, 2016 01:37 PM
clarkchriston
May 25, 2012 10:44 AM
64 stroker
Apr 27, 2009 09:03 PM
vetto
Shovelhead
Oct 14, 2008 09:05 PM
