2006 FLHT studdering at 1800-2500 RPM
Old Jul 9, 2007 | 07:50 PM
bluesguitar's Avatar
bluesguitar
Default 2006 FLHT studdering at 1800-2500 RPM
The bike has bassini megs, 211 cams, shaved heads around 10:1 compression,stage 1 and air cleaner. I has this studder in 1st gear at about 1800 rpm to about 2500, holding the throtle still. when you open it there's no problem it takes right off. I installed a PC111 tried 3 down loads and still doe's the same thing. I guess I'm going to the dyno. Any ideas. [X(]
Old Jul 11, 2007 | 06:54 AM
Doc 1's Avatar
Doc 1
Default RE: 2006 FLHT studdering at 1800-2500 RPM
I believe we talked on the phone......one thing I didn't mention or ask you is did you set the throttle position in the PC. It should read 0 at idle and at wot it should read 100. With thisbeing off it will stammer down low.
Old Jul 11, 2007 | 12:25 PM
vette family's Avatar
vette family
What PC111 firmware are you running?
donald
jrounkles
Feb 16, 2020 09:37 PM
trosel238
Jul 28, 2012 07:57 AM
waynemags
Aug 3, 2010 02:45 PM
Old Gray Beard
Nov 6, 2008 06:32 AM
GlennsGlide
Dec 17, 2007 05:19 AM
