need advice on engine build and tools
Old Jul 15, 2007 | 01:26 AM
olgreydog7's Avatar
olgreydog7
Default need advice on engine build and tools
I'm fairly experianced with car engine builds, but I'm new to HD's. I have a 2004 FLHRS with the Twin Cam 88. I need more power! I was thinking that since evos, pan, knucks, ect made good power with 80" or so, why do I need a big bore kit? I figure I could do some head work, mill the heads for a higher compression, install some cams, remap the EFI and be good to go. Am I wrong? Also, what speciatly tools would I need, I'm a do it yourself kinda guy. I would send the heads to a shop, but can I do cams, changing to gear drive, myself? If I did bore the cylinders, would they need to be re-sleeved? Thanks
Old Jul 15, 2007 | 05:21 AM
xxxflhrci's Avatar
xxxflhrci
Default RE: need advice on engine build and tools
If you are going to the trouble to take the heads off, you are only 300 bucks away from 95".........$129 for a SE flat top piston kit, $125 or so for boring, and the rest for a few orings/gaskets. Why not just go to 95"?
TikTok
Nov 21, 2014 08:56 PM
patriotmc
Dec 13, 2009 10:33 AM
rap87
Aug 27, 2007 06:30 PM
olgreydog7
Jul 16, 2007 12:28 AM
05flhpi
Jul 10, 2007 09:07 PM
