Best fitting headers for 2007 Ultra Screaming Eagle?
I would like to change out my stock headers with a quality set of true duals. I will be using the ThunderMax wide band sensors.
I have searched the various sites and it appears as though in some cases the Reinharts will position the front sensor in contact with the oil cooler adapter as well as hitting the base of the brake pedel.
The same is true for the V & H pipes except that the rear sensor will most likley hit the transmission top cover!
I know I can bend, shave and cut to make things work but I would prefer a factory fit. Has anyone tried the D&D 516-22d Dualies or the Bassani BX-115CL ??
If so, do the sensors and the brake pedel clear without modification?[/align]
