can i make this work?
Old Nov 13, 2011 | 03:24 PM
1968aj's Avatar
1968aj
Default can i make this work?
i picked up a rinehart true dual system today. it came off a 2006 street glide. i have a 2007 road king. mine has the o2 sensors but the true duals do not. does anybody know how i can make this work? i assume everything will fit .what can i do about the 02 sensors?
Old Nov 13, 2011 | 03:25 PM
Shredding rubber's Avatar
Shredding rubber
You can weld in 02 sensor bungs or you can buy a tuner that deletes them. Up to you.
Old Nov 13, 2011 | 03:29 PM
Stiggy's Avatar
Stiggy
Those are indeed your only 2 options.
( Tuner would be the simplest I suppose.)
Old Nov 13, 2011 | 03:32 PM
mkguitar's Avatar
mkguitar
just about any muffler shop will weld in bungs for you.
mount up the pipes first and mark the location ( the o2 sensor location isn't crucial, but you want to make sure you clear any brackets etc.)
let them know what thread/size o2 sensor bungs you need.
you could take in the old headers if you want, that'll help them
mike
Old Nov 13, 2011 | 04:27 PM
1968aj's Avatar
1968aj
what would it affect if i just put them on with no sensors?
Old Nov 13, 2011 | 05:00 PM
rlaf75's Avatar
rlaf75
Without a tuner or O2 sensors youre probably going to get a check engine light and it may run poorly.
Old Nov 13, 2011 | 05:02 PM
rlaf75's Avatar
rlaf75
And potentially damage the engine
Old Nov 13, 2011 | 05:23 PM
Captain Itch's Avatar
Captain Itch
Sponsor
Put a power commander on from Fuelmotto and your new exhaust and a high flow A/C AND YOU WILL NEVER LOOK BACK..
__________________
www.Captain-Itch.com
Old Nov 13, 2011 | 06:01 PM
1968aj's Avatar
1968aj
thanks for all the info. i had two different people tell me they made this swap without hooking up the sensors at all.it did not sound right.
Old Nov 13, 2011 | 07:24 PM
BackAt5O's Avatar
BackAt5O
You may have to modify the exhaust bracket that mounts to transmission on the right side. I modified a SE 2 into 1 that fit up to 2006 Road Kings and I had to cut two of the four mounting holes off to fit my 2007.
