se255 cam
Old Aug 3, 2007 | 07:33 PM
pwr96's Avatar
pwr96
Default se255 cam
Stock camsare out of engine,waiting on se203 to arrive.Having second thoughts.255 may be too much, but reading hd catalog they seem to have just what I want, high lift without se spring install while giving good bottom and mid range torque.Anybody installed a 255 into 96ci ?I have no plan for 103ci.Thanks for any info.
Old Aug 3, 2007 | 09:31 PM
racinjason's Avatar
racinjason
Default RE: se255 cam
Do not put that cam in your bike. It is a dog. The 203 is a much better choice.
Old Aug 3, 2007 | 10:09 PM
pwr96's Avatar
pwr96
Thanks for advice.Do you compare se203 toandrews 37h ?
Old Aug 3, 2007 | 10:49 PM
racinjason's Avatar
racinjason
They are dead on with each other. It would be a great choice as well.
Old Aug 3, 2007 | 10:53 PM
pwr96's Avatar
pwr96
Where does the se211 fit in the mix?Thanks
Old Aug 3, 2007 | 11:01 PM
racinjason's Avatar
racinjason
It's a good cam as well. The only thing about that cam is the power curve on it comes on a little later. About 3000 to 3500. If you are wanting that grunt from off throttle to redline, both the 203 and 204 or even the 37h is the ticket.
Old Aug 3, 2007 | 11:22 PM
pwr96's Avatar
pwr96
O.K. I had dyno last week,78hp 91tq.without sert or flash of any kind.Bought sert this week.I will down load just as soon as I finish cams.What kind of numbers can I get with 203 or 204?Thanks for your insights.
Old Aug 4, 2007 | 07:23 AM
racinjason's Avatar
racinjason
If you already have those good of numbers you shouldeasily be able to see somewhere in the neighborhood of mid 80's hp or even moreand 100's tq. good luck with it. Let me know how it tujrns out.
Old Aug 4, 2007 | 07:39 AM
pwr96's Avatar
pwr96
Thanks again for your help.I will let you know.I wonder if I should add fuel through cam rpm range?
Old Aug 4, 2007 | 02:27 PM
racinjason's Avatar
racinjason
If you are going to get it re-dynoed after the work, let them do it. That way it's dead on. It's going to run good!
