Pipe identification help
Old Jul 27, 2022 | 09:08 PM
Jordanxl1200c's Avatar
Jordanxl1200c
6th Gear
Default Pipe identification help
Just need some help if anyone knows what pipes these are by the look of them. New to me 07 xl1200c Arlen ness air cleaner, dynonet commander 3 and don’t know what the pipes are. Any idea?
Old Jul 28, 2022 | 11:36 AM
nevil's Avatar
nevil
They look like Cycle Shack mufflers that I used to run. Sometimes there are markings on the bottom of the can or inside facing the wheel. Seeing what the baffles look like can be a clue.
Old Jul 28, 2022 | 11:39 AM
Jordanxl1200c
6th Gear
sweet thank you I’ll check for markings and what the baffle looks like!
Old Jul 28, 2022 | 11:58 AM
Stiggy's Avatar
Stiggy
Check to see if the baffles are removable too (A bolt or two holding them in from the side?)
Old Jul 28, 2022 | 12:02 PM
Jordanxl1200c
6th Gear
if there is a bolt what does that tell me?
Old Jul 29, 2022 | 11:34 AM
nevil's Avatar
nevil
It's holding in the baffle, if there is one.
Old Jul 29, 2022 | 01:27 PM
Jordanxl1200c
6th Gear
obviously. But does it tell me what kind of pipes they are etc?
Old Jul 29, 2022 | 01:36 PM
nevil's Avatar
nevil
I thought you were asking about the bolt. Baffles can be unique from one brand to another, so having a good pic of it would probably help.
Old Jul 29, 2022 | 01:39 PM
Jordanxl1200c
6th Gear
someone else said something about bolts and I responded what does this tell me lol but yeah I’m not sure what pipes they are still I found some similar on j and p cycles and cycle shack ones look similar too I’ll have to check inside the pipes for some markings or underneath I’m thinking or send a picture of the baffles to you guys!
Old Jul 29, 2022 | 06:47 PM
smitty901's Avatar
smitty901
You posted an Exhaust on a 2007. 13 years old. there are many copy cats of pipes that sell.
Each bit of information supplied when ask helps narrow it down
Pipes with no stamping on them often means cheap copies. That makes it even harder. Supply all the information you can.
More and better pictures help.
