If you get a "bolt-in cam", you can use the stock length pushrods.Nearly every manufacturer makes a bolt-in cam.
Lifters? If my stock ones had more than 25k or so on them, I would replace them. The stock B lifters are hard to beat. However, if you want to save a few bucks, you can use small block Chevy lifters. I use Crane 10530 lifters in mine. They are the same lifter as the one Crane markets for the Twin Cam. They just have a different part number. The difference is price. Four with a HD number will set you back 200 bucks or so. Or, you can order 16 with the 10530 number for just under 200 bucks. I ordered 16 and sold 12 to other guys. I ended up with about 50 bucks in my lifters.
