Throttle play
Old Sep 24, 2007 | 11:02 PM
Navychief's Avatar
Navychief
Default Throttle play
I have a little play in the throttle grip and was wondering if a little tightening of the cable at the grip would cause any problems. I believe that as long as the idle cable returns the throttle to the closed position there will be no ill effects.
Old Sep 24, 2007 | 11:06 PM
Softy's Avatar
Softy
Default RE: Throttle play
You should have a small amount of play in the throttle. 2cents
Old Sep 24, 2007 | 11:40 PM
mentor70's Avatar
mentor70
When I switched to a Mikuni carb I noticed more play in my thottle too.
when I tried to adjust it out my carb would stick!
so now I have around a 1/8 in roll in the thottle now, I let a friend ride it the other day, and he said it felt OK to him. so I quess a little is fine.
Old Sep 25, 2007 | 05:03 AM
JLOCKHART29's Avatar
JLOCKHART29
You want to adjust your cable so that at full throtal roll you just make contact with carb throtal stop on a CV. If you need me to explain adjustment more I will.
Baja272
EVO
Feb 27, 2016 08:32 PM
9192daveyc
Feb 6, 2013 04:30 PM
fiveola
Shovelhead
May 6, 2008 11:17 PM
kylant
Feb 6, 2008 10:15 AM
HDF Tech
Jul 18, 2005 12:22 AM
