Dynamic Pressure equations.
Old Dec 1, 2007 | 10:35 AM
HD Attitude's Avatar
HD Attitude
Default Dynamic Pressure equations.
Im trying to find out the equation for dynamic pressure vs compression ratios. Reason why im asking is, I have 10:5.1 compression pistons. I want to run a compression test on the cylinders to see where I match up with the compression ratio. Also why is it so important to stay at 185 psi ?
Im trying not to over cam my bike and hold to the 10:5.1 ratio. (Max Power).
Old Dec 1, 2007 | 11:17 AM
maineultraclassic's Avatar
maineultraclassic
Default RE: Dynamic Pressure equations.
Here ya go................
http://bbhp.bigboyzheadporting.com/calculators.htm
Bean and George put them there for everyone to use.
Steve
Old Dec 3, 2007 | 06:09 AM
HD Attitude
I guess everyone missed my second question ????????
Old Dec 3, 2007 | 12:11 PM
maineultraclassic
ORIGINAL: HD Attitude
When you start getting over 190 CCP the starter can have a hard time turning the engine over.
My build as listed in my signature, has 190 CCP for each cylinder...............and I have some hot-restart issues in the summer time.
Steve
Old Dec 3, 2007 | 04:53 PM
mentor70's Avatar
mentor70
I have200 lbs of cranking cylinder presure, without comp. releases id be F**ked all the time!
The other issue is timming, and a true 10 to 1 comp. or higher you need to drop alittle timming for the detonation issues that will arise!
cruzmisl
13
Sep 24, 2012 06:23 AM
markymark02
17
Dec 13, 2011 02:04 PM
Bluehighways
Jan 30, 2011 05:48 PM
Scrubdog
EVO
Feb 9, 2009 04:34 PM
notarheli
May 7, 2008 02:26 PM
