Thunder header exhaust
As for the tune, what I would recommend is buying a Daytona Twin Tec WEGOII(afr monitor easy to hook up and install btw)and buy a SE SERT. Stay away from reflashes, every reflash is what I call a $150 waste of money. The SERT combined with a WEGOII will allow you to tune and retune your bike effectively as you make changes and is a much better long term solution both for the performance of the bike, and your wallet(you will spend more upfront, but much less in the long run). In fact I think Daytona Twin Tec just cam out with their Twin Scan 88+ which is made specifically for tuning the sert easily with a WEGO monitor.
There are a few folks here including myself who can help you through the programming process if you need help. But if your still waiting for the bike, pick it up ahead of time and get yourself aquainted with the software. Looks challenging at first, but with time spent learning up on it and understanding it you will find its pretty straight forward.
Zanottis sells the SERT for about 25% off retail, and www.partsthatfithd.com sells the Daytona Twin Tech kit at a discount also thats worth your time.
I like the way you're thinking and agree with what Mega said! That direction will help you now and leave you options for however you go in the future. As for exhaust, Cycle Shack "M" series slip ons are proven performers and have the look and sound that will complement your scooter. You'll be able to use them downstream too.
One other thing you might look into is whether a switch to 3.37 gears would be a benefit. It makes a noticeable difference in acceleration in pre-'06s, but given you have a 6-speed and I think they are they are already geared a bit lower - I'm not sure it would help or hurt. Maybe someone else more knowledgeable can weigh in here and provide better insight.
. Altough I love the performance, I am not wild about the looks of a 2into1 pipe on my bike.
I like it to. Looks Bad ***[sm=signs007.gif]
Good Luck!
Thunder Header 2 into 1's are AWESOME!! Great sound, great look. Seach the net for the comparisons -- these pipes smoke slip on's and true duals in regards to horse power. Plus, you can get the false left side to balance the look of your bagger.
Good Luck!
