Engine Case Replacement - EVO
Old Jan 4, 2008 | 12:04 PM
Clifton63's Avatar
Clifton63
Default Engine Case Replacement - EVO
I finally found a used 1996 evo case to replace my cracked 1994 case. I bought new timken bearings and races for the left side crankshaft, however the right side crankshaft main (pinion) race is missing from the new case. Can I use the right side race (and pinion shaft bearing) from my old case and have it pressed in to the new case? Will this require "line lapping"? The old bearing and race are in excellent shape to use.The new Timken races will need to be pressed into the left side as well.
Old Jan 4, 2008 | 12:36 PM
street racer's Avatar
street racer
Default RE: Engine Case Replacement - EVO
Go with a new right race.Pressing the old one out may damage it.You can get a replacement race from JIMS.And you will have to line lap after the installation of the new race.You have the motor down this far anyways.Do it right.
Jpcl
EVO
Jan 30, 2018 07:59 PM
harleyrider37
Engine Mechanical Topics
Jul 2, 2017 03:52 PM
97EvoBasket
Aug 27, 2013 12:22 PM
megawatt
EVO
Mar 12, 2013 06:46 PM
Clifton63
Jan 2, 2008 07:28 PM
