compresion
Old Jan 30, 2008 | 07:00 PM
snod's Avatar
snod
Default compresion
I have A 08 96ci 9.2:1 if I do the .030 head gasket what do I get?
Old Jan 30, 2008 | 07:10 PM
wadejesu's Avatar
wadejesu
Default RE: compresion
You will probably have oil leaking all over cause you will forget something. If yor goiing to pull the heads, Do more, Cams, Porting, etc
Old Jan 30, 2008 | 07:36 PM
snod's Avatar
snod
ok i have 37 cam And A good indy just thinking compression.
Old Jan 30, 2008 | 07:40 PM
fxrp's Avatar
fxrp
Too many variables here. But if you drop.020" from the stock (approx .050")gasket to a .030" and you are at 9.2:1 you would be9.5:1. You got to pull it apartand take some measurements to know.
Old Jan 30, 2008 | 07:49 PM
snod's Avatar
snod
thanx fxrp that was my question.Hell I cant type let alone build a motor..HeHe...
Old Jan 30, 2008 | 10:21 PM
Papamte's Avatar
Papamte
Snod, go to Bigboyzracing.com and use their compression calculator. You just load in your engine variables and it does the rest. They give you examples and prefill the boxes so all you do is change what needs to be changed. It will also let you see what effect different cams and other modifications will do to the compression.
Road Star
Engine Mechanical Topics
Aug 9, 2017 05:48 AM
nottaway
Aug 28, 2015 10:36 AM
InthewindMN
13
Feb 20, 2015 07:20 PM
carltex
Dec 26, 2010 10:58 AM
harris48cars
Apr 27, 2006 01:27 AM
