Cam Check
Old Jan 19, 2006 | 03:23 PM
Reffixer's Avatar
Reffixer
6th Gear
Default Cam Check
1975 XLH Ironhead Sportster. +.040 pistons, otherwise stock. Exhaust=Drag pipes w/some kind if fiberglass embedded baffeles.
Is there any way to check what kind of cam shafts are installed in this bike.
Would measureing the height, or travel of the lifters give any indication.
If it DOES happen to have non stock cams, should I adjust the timeing back a little from factory stock @40degrees BTDC. so it does'nt run soo hot.
I always use priemium fuel. Valvoline 50 wt oil.
Thanks,
Reffixer.
Old Jan 19, 2006 | 03:41 PM
95cdman's Avatar
95cdman
Default RE: Cam Check
Your going to have to pull the cams to figure out who made em and their part #.
Old Jan 19, 2006 | 10:01 PM
baggersport's Avatar
baggersport
ORIGINAL: Reffixer
Thanks,
Reffixer.
Yes fixxer, you can do as you say. Use a degree wheel and measure the lifter travel for cam timing. You would have to compare your specs. to those of the different manufacturers. Lift would take into account any rocker ratios. IMO, I would loosen the pushrods and remove the cover, if your careful you can keep the cams from falling out and remove only one for a number. You may not get a name but you should be able to determine whose part from the number.
Old Jan 20, 2006 | 01:12 PM
95cdman's Avatar
95cdman
ORIGINAL: baggersport
There are too many cam's with very similiar grind profiles, using a degree wheel is not going to tell you what you have in there with any accuracy especially without knowing the mfg. of the cam and how it measures its own cam specs, especially on an older bike. The cams will need to be removed and inspected physcially.
Strtspdlx
Engine Mechanical Topics
Aug 16, 2017 02:20 PM
kllrvet
Milwaukee Eight (M8)
Jul 2, 2017 07:19 PM
Stopit
13
Feb 17, 2014 09:20 PM
jhughes484
May 9, 2010 09:06 PM
harleyman1340
Apr 10, 2010 10:20 PM
