ReWorking heads
Old Feb 17, 2008 | 10:42 AM
SoBRick's Avatar
SoBRick
Stage II
Default ReWorking heads
A shop here in central New Mexico (New Life Builders) welds up and remills stock heads. They claim great results.
Any info, opinions or ideas on this shop or process?
Old Feb 17, 2008 | 11:28 AM
skyhook's Avatar
skyhook
Default RE: ReWorking heads
do you mean weld the port for velocity?...some of the industry leaders do this with good results...don't know anything about that shop you mention
Old Feb 17, 2008 | 12:07 PM
Old Gunny's Avatar
Old Gunny
Newer HD stock heads don't weld well. Something to do with the metal they are made out of. Too much Zink?? I have been told.
Old Feb 17, 2008 | 12:42 PM
mtclassic's Avatar
mtclassic
Dewey is in nm I believe. www.deweyspegs.com
Old Feb 17, 2008 | 12:52 PM
fxrp's Avatar
fxrp
Dewey is retiring. If he has already stopped he has sold/passed on the name and product to a reputable porter. Contact him. I believe he's in Farmington.
Old Feb 18, 2008 | 08:42 AM
bobcowan's Avatar
bobcowan
The new heads are pretty darn good right out of the box. Unless you're doing something radical, it's not worth the expense. Or so the pro's tell me.
If you are doing something radical, try to have the heads ported by the same people who supply the rest of the parts/work.
Old Feb 18, 2008 | 08:58 AM
fxrp's Avatar
fxrp
ORIGINAL: bobcowan
That's true but only partially.
The '06 and later heads are much better, particularly in the ports and the valve springs. But for cost savings the MoCo went to a 1.80 intake valve (bad move). The cost savings is they only buy one size valve for all their heads, that includes Sportsters.
If you have the heads off an '06 and later bike, if nothing else have a good shop install a 1.90 intake valve. Its inexpensive andwill make a significant difference in performance.
Old Feb 18, 2008 | 09:09 AM
nmfxstc's Avatar
nmfxstc
New Life Builders used to be in Los Lunas....they have a motto: "Performance Bulit in, Not Bolted on"...I hear they do a sweet job building engines...not sure about the rest (electrical, etc.)
The 96" engine is no slouch though...the cost benefit ratio is sokething to consider...the Twinkie is pretty damned reliable as is.
Old Feb 18, 2008 | 12:37 PM
Kingofcubes's Avatar
Kingofcubes
ORIGINAL: SoBRick
I like the welded and cnc ported stuff by R&R because they took the David Vizard technology and took the core shift out of it. Ports 30% smaller they make the bike rev much quicker (nothing obnoxious). Cool the engine down 30-50 degrees also. 108-110 H&T with 95"'s.
Old Feb 19, 2008 | 11:51 AM
SoBRick's Avatar
SoBRick
Stage II
Thanks all, I had them (new life) dyno and tune and am mostly happy. 70 hp and 90ft. I'm looking to the future and have been told that re milling is bad and that its good. I think he welds up the whole head ports and all.
Thanks again.
les_garten
Screamin Eagle CVO Models
20
Dec 11, 2019 10:06 AM
Captain Itch
Vendor For Sale Classifieds
Feb 22, 2018 02:20 PM
Greabert
Dec 3, 2013 12:27 PM
Tltrump
Dec 28, 2007 06:04 AM
Tfrosst
Nov 14, 2007 07:38 PM
