Spark Plug Question
Old Jan 30, 2006 | 03:35 PM
haywood's Avatar
haywood
Default Spark Plug Question
After rejetting My stock Carb with 48 and 190 jets, idle adjustment screw 2 1/4 out, and installing SE air cleaner and VH Big shot staggerds. The front cylinder spark plug is nice and tan but the rear cylinder plug gets black and sutty. Should the plugs be close to the same color or does the rear plug tend to get a lot blacker.
Should I troubleshoot somewhere besides the carb?
Thanks,
99 Wide Glide TC 88
California Model with the canister removed
VH Big shot Staggered
Stock Carb
SE Air Cleaner
Andrews 26 G
Thanks,
Haywood
Old Jan 30, 2006 | 05:06 PM
HDF Tech's Avatar
HDF Tech
Default RE: Spark Plug Question
The 48 sounds a bit big, a 46 would be better, the rear plug will run a bit darker than the front and also hotter. Reading plugs is telling you very little nowadays. The additives is all you are usually seeing for color on the plugs since the lead has been removed that gave it the color. If you try a different gas, you probably will have a white insulator.
https://www.hdforums.com/m_66688/tm.htm
Old Jan 30, 2006 | 11:21 PM
Unbalanced's Avatar
Unbalanced
Some interesting reading for those inclined.
http://www.dragstuff.com/techarticle...ead-plugs.html
dynarider77
May 5, 2018 10:39 PM
89FLHTC
Oct 22, 2015 10:46 AM
ricaroo
May 1, 2011 09:32 AM
PMZ XL 1200
Apr 19, 2007 08:58 AM
doakley2
Dec 12, 2006 12:54 PM
