Plugs
Old Apr 21, 2018 | 08:31 AM
dynarider77's Avatar
dynarider77
6th Gear
Default Plugs
whats up fellow riders ! I have a question and maybe a dumb question. I have a 2004 dyna wide with stock motor and vance n hines longshots and with a hypercharger. I know some will say your hypercharger is the issue but i don't believe it is. The issue i am having is that i keep fouling out plugs on the rear cylinder. Whats wierd is that when i am riding normally vs just giving her hell it seems to run ok but once i giver hell she spits sputters like the plug is fouled. Then i take the front front plug out and its clean. And the i take out the rear plug and it has black soot on it. Hopefully somenone will be able to help me out on trying to figure it . I have changed the plug wires and ignition coil. Thanks for your time.
Old Apr 21, 2018 | 09:20 AM
jbarr1's Avatar
jbarr1
Check for intake leaks first. Is it carb or fuel injection? What tuning has been done? Stock plugs?
Old Apr 21, 2018 | 09:25 AM
dynarider77
6th Gear
Default Carb
Its carburated and i was using champion but switched to ngk and still the same issue.
Old Apr 21, 2018 | 10:44 PM
marcodarq's Avatar
marcodarq
Check out for vacum leaks, once that is covered confirm that yout carb jetting is correct. The best way forvthatbis a trip to the dyno.
M
Old Apr 26, 2018 | 12:18 PM
FLTRI17's Avatar
FLTRI17
Since your bike is 14+ years old it’s very conceivable you have an intake leak from front cylinder intake leak causing a lean condition. If someone has rejetted the carb they could have tried to cover up the lean cylinder by over-richening the mixture which, in turn, would make the engine run excessively rich on the cyclinder without the intake leak.
Also, I would swap plugs frt to rear to assure the same issue repeats.
Bob
Old Apr 26, 2018 | 12:25 PM
Zanthamos's Avatar
Zanthamos
How is your oil level? Could have a rear ring issue as well but not very likely.
Old May 5, 2018 | 10:39 PM
1997bagger's Avatar
1997bagger
It is possible, 15 minute compression test along with checking for a intake leak is good base diagnostics with a older engine. Everybody knows that.
dynarider77
Apr 22, 2018 04:51 PM
89FLHTC
Oct 22, 2015 10:46 AM
Delawaredave
EVO
24
Jul 2, 2014 04:55 PM
PMZ XL 1200
Apr 19, 2007 08:58 AM
doakley2
Dec 12, 2006 12:54 PM
