78 flh top speed only 65mph , good comp. , new electronic ing. , new coil & wires , new carb (s&s G) ,new fuel lines ,filter , petcock , new intake & O-rings ,new ing. switch , new wiring harness . Bike runs strong in neutral but in gear it bogs - stalls .cant keep throwing moneyatit !!! please help !!!
not 100% sure of timing - timing mark hard to see , dont think carb is to big same prob. with S&S E , motor was built ,S&S rods & pistons with longer than stock stroke ,sifton cam & andrews gears . bike used - fly
An S&S G carb will feed 113" and 124" engines. It is MUCH too large for your 80" Shovel.
You will need to jet up, and in a big way, as the signal it is recieving from your powerplant is not enough to wick gas up out of the bowl.
BTW, what are the jet sizes?
the S&S E worked fine for a few years , then I had intermintint power loss , now I only have power when in neutral , runs very strong - try to ride -now only goes 15 to 20 mph . been trying different parts to fix , nothing works
