General cam question
Old Feb 18, 2006 | 08:20 PM
fxdxsteve's Avatar
fxdxsteve
Default RE: General cam question
If the chains drive cam's are so bad why does S&S, Andrews, still offer them?
because some people have to learn the hard way , also a lot of people own their bikes for a long time and put very few miles on them so they don't wear as much but the higher the lift the more pressure you put on them so they wear faster also how hard you ride matters too mine were shot at 12000
steve
Old Feb 18, 2006 | 09:38 PM
George C's Avatar
George C
Lots of drama from that guy...
Like I said above, if a guy wants to spend another $400.00 for geared cams, then great, but don't mislead the public and blow the old cam tensioner problems into something they aren't.. Yeah, there was a problem right up to the 03' MY, but they have been addressed.
The new bikes come with polished chains and a different material for the tensioner. I guess after 25,000 miles, it wouldn't be a bad idea to check them, but they certainly aren't a " ticking time bomb waiting to explode, destroy your motor, and cost you alot of grief."
Old Feb 18, 2006 | 10:35 PM
roadglide65's Avatar
roadglide65
Geezer
You'll be fine. only the Dyna have differant cam set up.
Old Feb 18, 2006 | 10:42 PM
roadglide65
George
No **** on the drama.
I think i will leave before i blow up.
Old Feb 19, 2006 | 01:30 AM
bobcowan's Avatar
bobcowan
ORIGINAL: Electra Geezer
ORIGINAL: bobcowan
But there are no gear cams available for the '06 yet. So for now, I'll use SE chain driven.
Maybe I've been in some sort of vacuum but this is the first time I've heard that you can not install the S&S gear drive kit on an 06. Is that true for the all 06 Dyna's or does it apply to the 06 EG also?
Only the Dynas have this new cam plate. The cam plate, cams, bearings, chains, and tensioners are all differant than the '05's and the other TC motors. Nothing interchanges.
Is a gear drive better than chain drive? Strictly from a mechanical point of view, Of Course It Is!! Fewer moving parts, less wear and tear, etc, etc, etc. But, it's all in the execution. There were a lot of problems with the early chain drives. And I think they have been addressed and resolved reasonably well. Unless you run high spring pressures, I think they will be fine. If I even had a hint that this was a, "Ticking time bomb", I wouldn't buy the bike. Every so often I'll open it up and take a look. Besides, there's no other choice at the moment. So it's a dead issue.
I spoke with a local engine builder today. Here's what I learned about the stock '06 Dyna heads:
1. Max valve lift is .550.
2. Off the shelf flow rates are very good. A simple 30 minute clean up and a 5 angle valve job and they flow "better than most SE heads". Very encouraging. Also, the now stock beehive springs are excellent - as I suspected.
So the decision has been made, partly by default. SE 204 chain drive cam, mild port and polish job, SE 95" cylinders, high compression cast piston, SERT, slip ons, SE air cleaner. Effective cylinder pressures here at 6,500' asl will be about 168; the same pressure as a stock engine at sea level. Should run well all day long with mid grade pump gas in pretty much any condition I might encounter.
Thanx for all your help. It's nice to pass these ideas around and get varying viewpoints.
Old Feb 21, 2006 | 10:30 AM
FASTFXD's Avatar
FASTFXD
ORIGINAL: bobcowan
ORIGINAL: bobcowan
Bob,
I think you'll really like that combo! Keep us posted when you get it all set up!
GC
gpp
Oct 22, 2010 05:46 AM
cardboard
Oct 2, 2010 05:15 PM
scottyd
Aug 5, 2010 12:28 PM
bobby5
Oct 2, 2009 07:19 PM
bemisbunker
Jan 14, 2006 08:32 PM
