Engine miss
Old Apr 23, 2008 | 04:03 PM
morock48's Avatar
morock48
Stage II
Default Engine miss
Hello my brothers and sisters
I hav e a 2005 heritage with v&h big shot longs complete with fuel pak also a stage 1 kit. The problem i'm having is as follows. My bike has a high speed miss
and loss of power above 50mph, when i roll on the power at about 50 or 55 it seems flat, no acceleration. I have replaced plugs, plug wires and battery, also
a dealer outside of Flagstaff, az replaced the fuel line inside my fuel tank stating that i wasn't holding 60 lbs of fuel pressure as required, it seamed to fix the problem for about 400 miles then the problem returned. Also after i replaced the battery and rode about 250 miles and returned home the battery was dead the next morning. I have check all obvious signs of loose or broken wires, fuel leaks etc.
Any help would be greatly appreciated, thank you
morock48
Old Apr 23, 2008 | 06:37 PM
Old Gunny's Avatar
Old Gunny
Default RE: Engine miss
Sounded like a fuel filter and may be. but then, battery dead.
Take the battery to some shop capable of loading testing. Thats a good or bad test.
Keep the fuel filter in mine. That would have caused the earlier problem also. Didthe dealer, I wonder,clean the tank or at least check for debri in it? Could be crud just plugging up the new filter if they put one in.
Old Apr 24, 2008 | 08:27 AM
shoveltrev's Avatar
shoveltrev
it not charging, thats whats causing the miss too. have the charging system checked. trev ps on my ultra i noticed itmissing before i seen the voltmeter droppin.
Old Apr 29, 2008 | 01:41 AM
morock48's Avatar
morock48
Stage II
Thanks for your help, I think the problem is solved, I changed the fuel filter and changed both internal tank fuel hoses, replaced the voltage regulator and everything seems alright.
Once again thank you, stay safe.
flylock
Engine Mechanical Topics
Sep 1, 2018 09:00 AM
tjustice55
Aug 11, 2013 10:43 AM
Scubba2
Jun 29, 2012 09:03 AM
Georgepty
Apr 4, 2012 09:44 AM
BobO2002
Nov 21, 2007 04:45 PM
