How do I...
Old May 27, 2008 | 01:11 PM
95sportster883w1200's Avatar
95sportster883w1200
1st Gear
Default How do I...
Change a cam cover gasket on a 1995 sportster 883?????? I took out the cover bolts but i pull the cover and it stops. I called my local harley dealer and they told me i need to take aport to top end of the motor to releive pressure from the cam. if that is true its bull sh*t! I am pretty pissed because i thought it was just a cover. now i cant start it to take it to a shop because a peice of the old gasket fell inside.
Old May 28, 2008 | 08:21 AM
extech's Avatar
extech
Default RE: How do I...
They're right, the cams are supported by the cover and having the spring pressure on them will cause the cover to bind. after you relieve the pressure(btw,it's very simple) remove the cover very slowly, be really careful and make sure the cams stay in place in the engine.
Buy a service manual, they're cheap compaired to having dealer fix something you've already fooled with. The manual will have the procedure for replacing the cover including the torque specs. you'll need.
Kikwear
Sep 27, 2023 11:22 PM
TF3N
Feb 4, 2016 03:03 AM
JohnJohnson
Oct 21, 2015 11:42 AM
apetterez
Jul 24, 2014 05:53 PM
SoCalFXSTI
May 11, 2007 07:58 AM
