sae valvoline 60 weight in shovelhead?
Old Jun 1, 2008 | 04:32 PM
82flh's Avatar
82flh
Default sae valvoline 60 weight in shovelhead?
was told this wasnt for air cooled engines just dumped 3.5 quarts in there
i ran it before never a problem
any suggestions?
Old Jun 1, 2008 | 05:16 PM
wfolarry's Avatar
wfolarry
Default RE: sae valvoline 60 weight in shovelhead?
You won't have any problems. Run it. Used to run Kendall 70 in my Shovel. Never had a problem.
Old Jun 1, 2008 | 06:13 PM
82flh's Avatar
82flh
i always thought 60 weight was 60 weight?
Old Jun 1, 2008 | 07:55 PM
wfolarry's Avatar
wfolarry
Not always. The Kendall 70 was actually 50wt that had extra additives to make it perform like a 70wt. It was actually called 70 grade. The most important thing to watch for these days in motor oil are the additives or lack of. You're actually better off running a diesel motor oil that still has the additives in it that car oil had to remove because of the EPA. This goes for older cars as well. If you're running a flat tappet cam you should be running diesel oil now. The motorcycle specific oils are still formulated the same way but they charge you twice as much. Get a gallon of Mobil Delvac and you're good to go. I never was a fan of the Shell Rotella. Seen too many problems in diesel motors to trust that stuff in anything. But that's just my opinion. Others have used it without problems.
BassFace
Shovelhead
29
Aug 14, 2016 09:44 AM
hdultraclassic
Oil Archive (no new posts)
Oct 25, 2013 08:10 PM
dstrat1
Aug 22, 2012 09:14 AM
TwiZted Biker
Jul 18, 2010 07:16 AM
Cloakguard
Shovelhead
May 31, 2009 09:01 AM
