2000 Road King backfire HELP!!!!
Old Mar 1, 2006 | 10:00 PM
Randcoll's Avatar
Randcoll
Default 2000 Road King backfire HELP!!!!
I recently had the Gear Drive Cam(S&S 510) upgrade done on my 2000 Road King. It has stage one and Harley Touring mufflers. When I got it back it had a lot of decel popping. I had it dyno'd and the dealer said the fuel mixture was within limits. I took it to an independent and had a DFO installed and had the mapping washed. Fuel intake checked. Mufflers and pipes checked, changed and tightned. Gear drive cam removed and replaced. Electronic box(ECM ?) replaced. Throttle housing replaced. Still poppng. HELP!!!
Old Mar 1, 2006 | 11:21 PM
MACK's Avatar
MACK
Default RE: 2000 Road King backfire HELP!!!!
YOU MAY NEVER GET IT TO STOP. I WENT THROUGH ALL THAT AND COULD NEVER STOP IT.
Old Mar 2, 2006 | 12:57 AM
GrayRider's Avatar
GrayRider
A good tuner should be able to get the pop out. However if you'll have the crossover plugged, making it a true dual system, it will stop after retune.
Old Mar 6, 2006 | 09:04 PM
roadkingchuck's Avatar
roadkingchuck
i had the same problem with my 2000 roadking. i found the header flanges were not replaced
correctly and cold air was seeping into the pipes causing the poping. you have to loosen the
header bolts and make sure the flanges are alined properly and tightened to spect.
Old Mar 8, 2006 | 08:09 PM
Randcoll's Avatar
Randcoll
They removed the headers and replaced them. Didn't help. They called today and said as soon as they put the true duals on, all popping stopped. Grayrider, thanks a lot! I was pricing new bikes and preparing to take a beating on the old one. Randy
Old Mar 8, 2006 | 08:50 PM
traveler's Avatar
traveler
I bet if you add just a little more fuel, it'll stop........popping is generally a sign of a lean mixture. if you're at like 13.7, then try 13.5, you don't want to fatten it up too much, as you'll lose power. the equalizing pipe is actually a performance enhancener.
joe
Dfszme
Jan 20, 2018 08:39 AM
5150northrider
Jun 1, 2017 11:11 PM
Slkrock
Dec 9, 2010 12:12 PM
INKANDBIKES
Oct 5, 2009 07:37 PM
gooberhd1
Nov 7, 2007 11:51 AM
