squeak
Old Jul 10, 2008 | 02:15 PM
kblend's Avatar
kblend
4th Gear
Default squeak
Man I hope you guys can help me with my problem. I recently bought my P111 and airfilter from Fuel Moto. Works excellent. But every since I changed my slipon exhaust (Samson Rolled Thunder / used ). I get this horrible Squeek until it warms up. Anybody know whats up. Thanks for your help
Old Jul 11, 2008 | 08:57 AM
kblend's Avatar
kblend
4th Gear
Default RE: squeak
got you guys baffled huh
Old Jul 11, 2008 | 09:46 AM
duke76's Avatar
duke76
Default RE: squeak
exahust leak
Old Jul 11, 2008 | 09:54 AM
ajayrk's Avatar
ajayrk
Default RE: squeak
Air leak.&nbsp\\; Put some high temperature RTV silicon sealant inside the inlet of the mufflers.&nbsp\\; &nbsp\\;
Old Jul 11, 2008 | 10:06 AM
duke76's Avatar
duke76
Default RE: squeak
I have typed about 3 responses to this and it wont let me respond
Old Jul 11, 2008 | 10:23 AM
extech's Avatar
extech
Default RE: squeak
I'd take a look at the saddlebag supports(loose) and the exhaust isolators(lube 'em with white grease).
Old Jul 11, 2008 | 12:07 PM
duke76's Avatar
duke76
Default RE: squeak
You can use a lighter to find the leak put the flame by the connections and see if the flame moves and if it does that is your leak and then use high temp silicone or better clamps to seal it up
Old Jul 11, 2008 | 01:14 PM
duke76's Avatar
duke76
Default RE: squeak
the noise goes away when it is hot because it expands and seals it up, the noise you are hearing is the exhaust leaking kinda like whistling
Old Jul 11, 2008 | 03:53 PM
ajayrk's Avatar
ajayrk
Default RE: squeak
Same problem here, but at least you don't have all those slash marks in your post.&nbsp\\; I'm using Firefox browser. What are you using?&nbsp\\; &nbsp\\;
Old Jul 11, 2008 | 09:10 PM
duke76's Avatar
duke76
Default RE: squeak
Im using internet exploder, to get from having the slash marks do not double space at the end of a sentence
Anton.N
Jun 9, 2021 09:44 AM
bobbyd3
Jul 26, 2008 06:33 PM
shortleg
Jul 13, 2008 03:21 PM
boneyard75
Jun 14, 2008 08:59 PM
DeuceRyder
Jun 10, 2008 09:02 PM
