Cam thrust washer?
Old Jul 26, 2008 | 12:38 PM
quigley's Avatar
quigley
Default Cam thrust washer?
What is the purpose of a cam thrust washer? If there is a clearance of 005 to 050 between the washer and cam I dont understand the purpose for it. Can someone please educate me?
Thanks Quigley
Old Jul 26, 2008 | 05:37 PM
rbabos's Avatar
rbabos
Default RE: Cam thrust washer?
Probably for chain alignment.
Ron
Old Jul 26, 2008 | 06:18 PM
quigley's Avatar
quigley
There is no chain , its a gear driven cam.
Quigley
Old Jul 26, 2008 | 06:56 PM
Doc 1's Avatar
Doc 1
The cam is designed to run up against the metal washer os it won't slap back and forth wearing out the cam bushing in the cam cover so hence the name Thrust Washer.
Old Jul 26, 2008 | 07:05 PM
quigley's Avatar
quigley
Thats what I'm confused about. How can it run up against it when you have a end clearance of 005 to 050 between the washer and cam? Please explain this to me.
Thanks Milan
Old Jul 26, 2008 | 07:13 PM
Doc 1's Avatar
Doc 1
The thrust direction was cut into the cam and pinion gear.
Old Jul 26, 2008 | 08:01 PM
quigley's Avatar
quigley
I have no idea what you just said.
Quigley
ORIGINAL: Doc 1
Old Jul 26, 2008 | 09:04 PM
gs34doc's Avatar
gs34doc
Big Kahuna HDF Member
The clearance is a running clearance. Needed for expansion and proper lubrication. When an object spins...a cam, a crank,the rotor in an electric motor, etc the spinning force causes the rotating member to Thrust in one direction or the other, depending on direction of rotation. The thrust washer is to protect the rotating and non rotating surfaces from being damaged by this action.
How'd I do Doc? Did I get that right?
Old Jul 26, 2008 | 10:50 PM
quigley's Avatar
quigley
That makes sense.Thanks for the education.
Quigley
Old Jul 26, 2008 | 11:40 PM
Doc 1's Avatar
Doc 1
Close enough....the forum keeps deleting my post if I try to type out a decent explanation.&nbsp\\; The cam gear and pinion gear are cut a certin way to make the cam thrust back against the case not the cam cover.
