K&N question
Old Nov 29, 2008 | 10:22 AM
hdpearl70's Avatar
hdpearl70
Default K&N question
Hi,
New to the forum. Great site! I just got my 1st bagger( pic coming soon) 07' FLHTP 103". K&N is telling me they do not make a air filter for my bike? Has anyone else run into this problem? I thought maybe you could use a custom application for an earlier SE engine? Any input would be great. Thanks alot!
Old Nov 29, 2008 | 06:22 PM
Shovelhead Bob's Avatar
Shovelhead Bob
http://www.knfilters.com/search/prod...x?Prod=HD-1499
This link is for the filter that you need... Whoever you spoke to is incorrect in their response to you....
This is the OE Replacement for your bike....
Old Nov 29, 2008 | 09:09 PM
hdpearl70's Avatar
hdpearl70
I questioned this part# when they said it won't work. The vehicle application page doesn't list an air filter for a 103". Do you know if the new backplate will match up? Thanks
Old Nov 29, 2008 | 10:38 PM
Shovelhead Bob
Motor size is irrelevant, as that has no bearing.....
An 88/95/96/103/110/113/120/124/131" motor all use the same type of air cleaner assy...
For instance, you go to the local bike shop to get a Stock AC (Filter), you are going to get the same one for a 96" motor....
Your bike doesn't have anything different from a production 96, other than bigger bore, cams, unique ECM calibration, ACR's and an oil cooler....
The external motor dimensions are the EXACT SAME.....
Also, What NEW backplate are you referring to??? If your backplate is an aluminum plate (Not the OE Black plastic bowl), then you will need the HD-0800 http://www.knfilters.com/search/prod...x?Prod=HD-0800
Old Nov 30, 2008 | 07:21 AM
hdpearl70's Avatar
hdpearl70
Thanks alot, You've been very helpful
yso191
Nov 17, 2010 06:05 AM
cdestuck
Aug 31, 2010 10:47 PM
CKinAZ
16
May 16, 2009 11:06 AM
0o0ow
Oct 5, 2008 04:18 PM
Mountainkowboy
Jan 29, 2007 09:23 AM
