Quiet gear driven cam
Old Dec 21, 2008 | 02:46 PM
Rebel78's Avatar
Rebel78
Default Quiet gear driven cam
Whats the quietest gear driven cam available? Any specific bran or model?
Old Dec 21, 2008 | 05:09 PM
FXSTDSE2's Avatar
FXSTDSE2
Is this a trick question? A cam whether gear drive or chain drive makes relatively no noise. A correctly installed gear drive makes minimal noise to the tune of a quiet whirling. If you run louder pipes then stock, you usually do not hear the gears. Improper backlash or excessive crank run out will increase the noise from the gear drive kit. Now for what is talked about as CAM noise usually relates the the grind of the cam and whether the lifters are able to maintain the proper lash to keep the valves quiet. A high lift short duration cam can be "noisier" than a lower lift cam.
Scunny highway
EVO
15
Apr 22, 2015 05:30 PM
Jack D
Dec 28, 2012 08:17 PM
jkauffman86
EVO
22
Aug 16, 2012 04:39 PM
csbreeze
Feb 22, 2011 01:42 PM
Z
Dec 3, 2009 05:42 PM
