Gear Drivbe cam question...
Old Dec 28, 2012 | 07:44 PM
Jack D's Avatar
Jack D
Stage IV
Default Gear Drivbe cam question...
This may sound stupid so here goes...I have a 1450 twin cam, was told it has aftermarket cam, solid lifters...Question is does gear drive cams make "noise" ie do they have a distinct sound...sorry trying not to sound to dumb, so be kind...Thanks...Jack
Old Dec 28, 2012 | 07:46 PM
SLV's Avatar
SLV
Yes. They make a whirr or whine sound if you listen close enough and your pipes aren't so loud.
Old Dec 28, 2012 | 07:51 PM
chuck3049's Avatar
chuck3049
The one thing you want to find out is how much run-out you have on the crank, for some reason Harley's tolarence is 12 thou. gear drive you need to be less than couple thou. maybe think on going to hyd. ten. checking cam bearings, replace stock INA bearings with Timkin look at Gaterman lifters, with SE adjustable push rods. I would say yes to much noise is not good.
Old Dec 28, 2012 | 08:13 PM
Jack D's Avatar
Jack D
Stage IV
Its not a loud or bad sounding noise, it put me in mind of a gear drive blower on a car...
Old Dec 28, 2012 | 08:17 PM
Gigawitz's Avatar
Gigawitz
As earlier mentioned, the whining noise from gear drives really depends on how much runout there is as well as the ability of your mechanic to install them correctly..
If they are properly installed they have a slight whine that you will only hear if you are trying to.. It's a good sound, not a bad one..
Gear drives are far superior to chain for many reasons, that is the way to go..
Scunny highway
EVO
21
Apr 9, 2015 09:24 PM
jkauffman86
EVO
22
Aug 16, 2012 04:39 PM
patsac
Feb 8, 2012 02:56 PM
Z
Exhaust System Topics
Dec 3, 2009 05:42 PM
Rebel78
Dec 21, 2008 05:09 PM
