Backfiring
Old Apr 13, 2006 | 11:50 AM
RoadHogg's Avatar
RoadHogg
3rd Gear
Default Backfiring
Yeah,got a 1999 wide glide and its back firing,will it hurt the engine,what can I do to correct it?
Old Apr 13, 2006 | 01:16 PM
sedbiker62's Avatar
sedbiker62
Default RE: Backfiring
Is it backfireing throught the exhaust or through the breather?
Or both?
Steve[sm=icon_rock.gif]
Old Apr 14, 2006 | 07:54 PM
RoadHogg's Avatar
RoadHogg
3rd Gear
Exhaust is where its coming from
Old Apr 14, 2006 | 07:58 PM
vernh59's Avatar
vernh59
All the time or during decel?
Old Apr 14, 2006 | 11:09 PM
RoadHogg's Avatar
RoadHogg
3rd Gear
During throtte release,or decel,kinda thought maybe it was a head gasket blown?
Old Apr 15, 2006 | 12:45 AM
JohnK/Pa's Avatar
JohnK/Pa
Usually if it backfires out the exhaust it's running rich, if it coughs out the intake it's running lean. You could also check the exhaust to see if their are any cracks or leaks anywhere. If you have the baffles out of the exhaust and have it rich enough to keep it from coughing thru the intake you probibly have it rich enough to backfire out the exhaust.
Old Apr 15, 2006 | 10:05 AM
RoadHogg's Avatar
RoadHogg
3rd Gear
Question,what do you suggest,its not backfiring thru the carb,although its worth noting the idle screw had to be readjusted due to the fact that the spring which keeps it tight was broken and was replaced.
Old Apr 16, 2006 | 03:16 AM
jcardoza's Avatar
jcardoza
The condition you have is because of a lean condition due to your low speed jet. Go to the next size, then test ride. If this problem just started, and you did not add any new parts, you could have a clog in one of the circuts.
Old Apr 16, 2006 | 09:17 PM
RoadHogg's Avatar
RoadHogg
3rd Gear
Just to let you know,it had a blown head gasket,but thanks anyways
Unclescarhead
Dyna Parts
Apr 9, 2018 08:53 PM
Unclescarhead
Oct 15, 2017 10:25 AM
tcarson84
Feb 3, 2016 11:06 PM
sugarcoat
Oct 22, 2014 10:37 AM
electriciandude
Feb 28, 2009 08:37 PM
