Oil pump alignment screws
Old Mar 21, 2009 | 08:20 PM
Bill C's Avatar
Bill C
Default Oil pump alignment screws
Any ingenious ways to align the pump without the oil pump alignment screws? I don't mind spending the money for a set, but then I have to order them and it will be several days before I get by bike running.
Old Mar 21, 2009 | 08:48 PM
mtclassic's Avatar
mtclassic
just pull the spark plugs put the bike in 5th gear have someone spin the rear wheel as fast as they can while you alternately and slowly tighten the four bolts holding the oil pump. This works very good.
Old Mar 21, 2009 | 10:21 PM
TXCHOP's Avatar
TXCHOP
Maybe use a ferrule from a compression fitting over a longer bolt???? Not sure if it would work as i have the tool, but might be worth a look. Take a look in the brass department.
Old Mar 22, 2009 | 12:04 AM
Bill C's Avatar
Bill C
Thanks. Worse case I will spin the rear wheel.
Old Mar 22, 2009 | 12:21 AM
KumaRide's Avatar
KumaRide
+1. First loosely snug all 4 bolts by hand while spinning rear tire, plugs out, tighten per tq pattern gradually, slowly tightening each one... eventually getting them to tq specs.
Old Mar 22, 2009 | 09:24 AM
Old Gunny's Avatar
Old Gunny
Bill C, spinning the wheel while slowly tightening, is not the worse case, it is actually in my service manual.
On the new pump, rotors just float inside their space. This way lets them find their center.
Old Mar 23, 2009 | 03:53 PM
Hammer 03's Avatar
Hammer 03
Stage III
I think spinning works the best. I had a few different cam swaps and spun the first two with no problems. By the time I did the third I had the alignment screws and the motor ended up wet sumping. I pulled things loose, did the spin method and no problems. I'm thinking harley must have had some issues locating their drill holes.
just plain john
Apr 29, 2025 09:22 PM
Salmo pass
Engine Mechanical Topics
Mar 4, 2019 03:17 PM
05ROADGLIDE
Feb 21, 2011 06:38 PM
xwhyz1959
Feb 6, 2011 07:55 PM
xwhyz1959
Dec 30, 2010 07:25 PM
