stage iv 103 problem
Old Apr 14, 2009 | 01:54 PM
babysuge's Avatar
babysuge
Default stage iv 103 problem
here the problem i ordered a stage iv 103 for my 07 fatboy back on january 31 the freakin kit didnt come in until March 10 my stealer picked up my bike on march 12. all they had to do is put everything from the kit into my bike except for the clutch spring and the sert since im using my stock clutch spring and my pc iii. here is it almost a month since they had my bike and they cant get the freakin thing right what should i do i need you guys advice
Old Apr 14, 2009 | 02:35 PM
qtrracer's Avatar
qtrracer
Why are they telling you they can't get it right? I had an indy do mine, went with the SEST works great, also went with SE 251 cams instead of 260's and went with the SE MVA CNC Ported intead on the non-ported ones and the 58mm TB that is compatible with my cruise control. So I guess mine is not really an out of the box Stage IV.
Old Apr 14, 2009 | 05:17 PM
Bigbluefatboy's Avatar
Bigbluefatboy
We need more info, what do you mean they cant get it right? whats the problem they are running into? Are they having a problem with your clutch spring?
Old Apr 14, 2009 | 05:50 PM
babysuge's Avatar
babysuge
they said the bike is not getting enough fuel they also said that they swapped the pc III with a brand new one and still nothing i think they didnt recalibrate the ECU to give the bike more fuel after they did put high performance fuel injectors
Old Apr 14, 2009 | 09:17 PM
Shovelhead Bob's Avatar
Shovelhead Bob
First off, the recal of the ECU is a moot point, as you stated that you didn't need the SE Tuner.. That is where the correct map is... The PC probably can't compensate for the 4.89 Gms/Sec load, vice the 3.91 gms/Sec load that the stock injectors provide....
It would be in your best interest to utilize the SE Tuner, as it has the correct parameters for that unique build.... PC's can only adjust 25-30% from the Base Map that is in the ECM... And that is at the limit of the stock injectors (With a stock/legal ECM cal)...
Additionally, that build does MUCH better with a 2:1 pipe (That is what it was designed for... Higher HP, ok Tq)....
Professional opinion.... use the SE Tuner or trhe TTS Tuner, Less hardware, much more flexibility for "Off builds"....
Old Apr 14, 2009 | 09:37 PM
babysuge's Avatar
babysuge
thanks shovelhead bob for that good advice. the kit did come with the sert but my stealer only deals with pc III they use sert in there shop what should i do in your opinion? Also if i get the ECU recal can the PC work until i could get it to a local indy shop so they can install the sert for me?
Old Apr 14, 2009 | 10:11 PM
Shovelhead Bob
ECM recal is out of the question.... The only 103 flash that they have readily available is the "Legal" one in the DT II... and that will cost 150.00....
They are a HD Shop, and they know nothing about the SE Tuner... Scary....
I'd tell you to get them to flash it with the correct map (SE Tuner, if they can figure it out), and get it to a tuner that KNOWS and UNDERSTANDS the SE Tuner...
If you were near me, I would hook you up... Where in NY are you located???
Old Apr 14, 2009 | 10:33 PM
babysuge's Avatar
babysuge
I'm located in the bronx and yes there a hd shop that only pushes PC 3. they told me they would install sert but won't tune it that's what they told me when I purchased the kit it seems a bit strange to me being that its a hd product
Old Apr 14, 2009 | 10:48 PM
babysuge's Avatar
babysuge
They told me when I first purchased the kit that I don't need the sert since I have the pc but I can get it installed but have to take it somewher else to have it tune it seemed strange since its a hd shop and its a
Hdproduct your thoughts on that and if they can tune a pc how come they can't tune a sert
Old Apr 15, 2009 | 03:20 AM
domenicp7's Avatar
domenicp7
The HD shops do not know how to tune SE tuner is right on the money. You wouldn't believe the mess they left my engine in one cylinder lean the other rich decel pop robbing power , O2 sensors ruined beyond repair. Never again will I trust these yahoo's to tune anything.
