finned headbolt bridge
Old Apr 21, 2009 | 09:29 AM
mhughes600's Avatar
mhughes600
Default finned headbolt bridge
anyone have experience with these? dothey help with cooling
part# 43857-00
Old Apr 21, 2009 | 11:38 AM
maineultraclassic's Avatar
maineultraclassic
If anything they would hurt cooling by reducing air flow.
But, they do look good when they are installed.
Steve
Old Apr 21, 2009 | 12:00 PM
rh8234's Avatar
rh8234
I doubt that they help or hurt much. I agree that they look good though.
Old Apr 21, 2009 | 01:09 PM
paul s's Avatar
paul s
http://www.uh.edu/engines/epi1016.htm I think the difference would be minimal either way, but they are called "cooling fins".
Old Apr 21, 2009 | 02:04 PM
1711tab's Avatar
1711tab
part# 43857-00
Don't think they cool or add heat... They clean the head bolt area up and look nice...
Old Apr 21, 2009 | 07:36 PM
Bad Disposition's Avatar
Bad Disposition
Default Decorative fins
If you plan to install compression releases later on down the line they are a waste of money.
Old Apr 22, 2009 | 03:04 PM
mhughes600's Avatar
mhughes600
thanks foe the help. i am really just interested in getting the engine cooler, so i will hang on to the cash
Old Apr 22, 2009 | 03:16 PM
maineultraclassic
If you want the engine cooler, install an oil cooler......dropped my peak temps about 20-30 degrees.
Steve
Old Apr 22, 2009 | 07:10 PM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
I do not want anything like that near the plugs/wire.
Old Apr 22, 2009 | 07:23 PM
XTrooper3936's Avatar
XTrooper3936
Ok, time for a little reality check here. These bridges cause no problems whatsoever. As far worrying about them being "near the plugs/wires," this is an unnecessary concern because they aren't near the plugs. They have a wide V cut into them on the plug side which provides plenty of clearance from the plugs and lots of room for your socket. Checking the plugs is just as easy with these bridges as without. If you like the looks of them, get them. They won't cause you any trouble. Compression releases in your future? You'll have to sell them.
