New piston trashed
(I'm sure folks are tired of hearing about it)
Mildly ported heads CC'd at 79.6
.030 head gaskets
.015 shaved from heads - new valves w/ 3 bevel cut
Cylinders bored out .030
KB domed 9 cc pistons and rings fitted to cylinders by machinist at Harley dealer.
170 psi compression approx 10:1 at 6000 ft elevation
New bearings and races in bottom end
Time-sert "Big Serts" installed in case for new cylinder stud strength
Woods W6 cam
2000i ignition
Mikuni HR 40 carb
Supertrapp 2-1
I was taking the maiden voyage and had about 60 miles on the bike when I stopped for a beverage. When taking off, I killed the engine. I went to fire it back up and it was very slow turning over, then spun right up and fired up. I headed back down the highway toward home and started hearing a little popping going on. At first I thought it might be detonation but then dedided it was a head gasket leaking. Before I could shut it down to check it out, I lost the back cylinder. I pulled over and spotted the back left head bolt hanging out between the tranny and linkage. Lucky it wasn't lost on the highway. I had my follow vehicle run back to the town where I turned around and pick up a 12 point 3/8 socket to see if I could torque the head bolt back down. Unfortunately it was stripped. I couldn't believe the cylinder stud had pulled with proper torque and the Big Sert inserts.
I trailered it home and tore it down. The piston on the back cylinder had blown a chunk out near the back stud that had pulled. It trashed the top half inch of the cylinder wall in the same area without doing damage to the cylinder below that. The rings have aluminum mashed into them making them a part of the piston. The head and valves look like they have been sand blasted with pebbles.
The front cylinder looks just fine.
WTF happened to me?
Would it be worth while to contact KB Pistons or are there too many changes to pin the problem on the pistons?
Thanks for any opinions or remarks.
Don
Looks like the rings welded themselves to the wall of the cilender. Which tore the piston apart.
Two things
There is a chance the piston, and or, rings were fitted too tight. If this is the case the person doing the fitting. The piston and the rings are just what broke.
Break in. Did you do heat cycle breakin before you went on the first ride? Tremendous amount of heat at first at the rings. Can melt metal.
Good luck with this.
That really sucks, and you must be feeling sick about it.
Ron
Everything you did above is good.
What they add is several very short startups, run 10-15 sec, shut down. Let cool, doesn't take long. Do again. This lets the rings and cilender wall meet and do their first kissing without getting too hot.
I was led to believe the Harley wrench in the SLC, UT dealership had done lots of these. He had the pistons when he bored the cylinders out .030 and said he had fitted them to the cylinders. Hopefully he had the formula.
I have built three EVO's running KB pistons and I have a set in my '82 shovelhead and haven't had any problems. The EVOs are two at 9.5:1 and one at 10.8:1 compression. You do have to have a proper tune to avoid lean conditions and preignition.
http://www.shutterfly.com/lightbox/v...4ab00f16ca9e1e
Use name of mcmeadow@dcdi.net and password Harley
