overheat sensor
Old May 24, 2006 | 06:25 PM
2004 heritage's Avatar
2004 heritage
5th Gear
Default overheat sensor
i have a 04 heritage classic with stage 1 air filter and v&h straightshot hs pipes . i encountered an idleing problem while in traffic at the mb rally. it sounded like it was only hitting on 1 cylinder. after talking to a fellow rider he told me that this sounded like the overheat protection system activated and shut 1 cylinder down. i have the service manual but dont recall seeing any info on the subject . does anyone know of a publication with an article about this, and is it even on the softails . thanks in advance!
Old May 25, 2006 | 01:32 AM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
Default RE: overheat sensor
It's under Engine Heat Management (EFI) in the 2006 Dyna owners manual on Pg 92. There are 3 phases outlined. Phase 3 is where the EFI pulses are interrupted and air is drawn in to cool the engine (only when bike is stationary and at 356F)
BTW, if you aren't running 20w50 synthetic oil, you might wish to consider it. JMHO
Old May 25, 2006 | 11:54 AM
2004 heritage
5th Gear
thanks for the info , i will definitly look this up and i am using, syn3 ever since the break in oil was removed at the 500 mile mark.
captbob
Mar 28, 2017 06:02 AM
hyrax222
EVO
Mar 23, 2015 11:52 AM
foxmcf
Jun 2, 2009 07:56 PM
Born to twist
Jul 29, 2007 08:47 AM
tlindell
May 17, 2006 09:34 PM
