2006 Dyna's
Old Jul 27, 2007 | 07:30 PM
Born to twist's Avatar
Born to twist
3rd Gear
Default 2006 Dyna's
Why would Harley re-engineer the 2006 Dyna for less oil capacity (2 Qts) and install O2 sensors that create a hotter running motor with a 3 stage heat managment system and drop the 3 stage system on the 2007 models ? Any clues ?
Old Jul 27, 2007 | 09:07 PM
gman's Avatar
gman
Default RE: 2006 Dyna's
where are you seeing that the '06 dyna only holds 2 qts? the owners manual lists it as 3 quarts, and completly dry mine will use this much, but i usually run the oil level 1/2 way down the stick to help the oil misting in the AC. the 02 sensors are not what make the engines run hotter. it is the lean AFR that is set by the map installed into the ECU. wasn't aware there was a heat issue with the '06 dynas. first i heard of it. real issue is the '07 Ultras with lowers and the 96 c.i. engine. search the forum and you will find lots of discussion on this issue.
Old Jul 27, 2007 | 09:12 PM
Alias's Avatar
Alias
I've never had any problems with my06 Street Bob.
Old Jul 27, 2007 | 10:42 PM
TXSwede's Avatar
TXSwede
That is a CLASSIC first post, born to twist dude!
Old Jul 28, 2007 | 01:06 AM
CraigC's Avatar
CraigC
Never had a heat problem running in FL summer weather with +90% humidity.
Old Jul 28, 2007 | 07:27 AM
bronk's Avatar
bronk
?????????????????No probs with my 06 either.96 motors on the other hand have some serious heat issues.
Old Jul 29, 2007 | 03:28 AM
Motosurf's Avatar
Motosurf
My runs cool and spot on with even the 8 degree injectors!
06 Street Bob
Old Jul 29, 2007 | 08:47 AM
dubblist's Avatar
dubblist
Mine overheats but usually when it needs a oil change or sits outsode all day at work in 100 deg heat. I also put in 2.5-3 qts of Mobile1 VTwin and she's perfect.
timolien
Oct 9, 2007 06:13 PM
dynamolowrider
Sep 2, 2006 06:41 PM
Z6969
Jul 11, 2006 02:01 AM
2004 heritage
Exhaust System Topics
May 25, 2006 11:54 AM
OC
Oct 14, 2005 02:39 PM
